async function error
Hi team,
I am going to write a for loop which will generate several thousands get_data function by investor id for a list of stocks. If I am use sync method, it takes extremely long time to finish the task. Hence, I try to using Async approach to do so. Wonder it is possible? I try to implement the async approach as below code but I encountered run time error. Wonder what is the correct way to do so? Thanks.
import asyncio
#shareheld by each investor
async def get_HVH(id):
df, err = ek.get_data(
instruments = Custom_PeersRICs,
fields = ['TR.SharesHeldValue'],
parameters = {'legacyInvestorId':str(id),'Scale':Scaling.value}
return df.iloc[:,1]
async def main():
tbl=pd.DataFrame(columns = Custom_PeersRICs)
for i in range(Output_Number.value):
id=output['investorid'][i]
hvh=loop.create_task(get_HVH(id))
print(i)
tbl_length=len(tbl)
tbl.loc[tbl_length]=list(hvh)
await asyncio
if __name__ == '__main__':
loop = asyncio.get_event_loop()
loop.run_until_complete(main())
loop.close()
Error msg
RuntimeError                              Traceback (most recent call last)
<ipython-input-21-d4e8b324361a> in <module>
     21      22 loop = asyncio.get_event_loop()
---> 23 loop.run_until_complete(main())
     24 loop.close()
/opt/conda/lib/python3.7/site-packages/nest_asyncio.py in run_until_complete(self, future)
     93                 raise RuntimeError(
     94                     'Event loop stopped before Future completed.')
---> 95             return f.result()
     96         finally:
     97             events._set_running_loop(old_running_loop)
/opt/conda/lib/python3.7/asyncio/futures.py in result(self)
    176         self.__log_traceback = False
    177         if self._exception is not None:
--> 178             raise self._exception
    179         return self._result
    180
/opt/conda/lib/python3.7/asyncio/tasks.py in __step(***failed resolving arguments***)
    247                 # We use the `send` method directly, because coroutines
    248                 # don't have `__iter__` and `__next__` methods.
--> 249                 result = coro.send(None)
    250             else:
    251                 result = coro.throw(exc)
<ipython-input-21-d4e8b324361a> in main()
     17         print(i)
     18         tbl_length=len(tbl)
---> 19         tbl.loc[tbl_length]=list(hvh)
     20         await asyncio
     21
/opt/conda/lib/python3.7/asyncio/futures.py in __await__(self)
    260             yield self  # This tells Task to wait for completion.
    261         if not self.done():
--> 262             raise RuntimeError("await wasn't used with future")
    263         return self.result()  # May raise too.
    264
RuntimeError: await wasn't used with future
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonasynchronous
@sunny.to
I am new to the asyncio. However, I assume that you would like to send requests concurrently. I found how to turn Python sync functions to async after searching via google.
The code that I tested is:
import asyncio
import eikon as ek
import pandas as pd
import logging
import sys,os,os.path
import time
import threading
import functools
def force_async(fn):
    turns a sync function to async function using threads
    from concurrent.futures import ThreadPoolExecutor
    import asyncio
    pool = ThreadPoolExecutor()
    @functools.wraps(fn)
    def wrapper(*args, **kwargs):
        global sem
        sem.acquire()
        future = pool.submit(fn, *args, **kwargs)
        return asyncio.wrap_future(future)  # make it awaitable
    return wrapper
@force_async
def get_HVH(id):
    global sem
    df, err = ek.get_data(instruments = id,
                          parameters = {})
    sem.release()
    print(df)
    return df.iloc[:,1]
async def main():
    chain, err = ek.get_data("0#.FTSE",["TR.RIC"])
    print(chain)
    output = chain['Instrument']
    hvh = []
    for i in range(len(output)):
        id=output[i]
        hvh.append(get_HVH(id))
        print(i)
    await asyncio.wait(hvh, return_when=asyncio.ALL_COMPLETED)
    print("asyncio.as_completed")
    start = time.time()
    sem = threading.Semaphore(20)
    ek.set_app_key("<app key>")
    print("Loop Close");
    loop.close()
    end = time.time()
    print(end - start)
The above code subscribes to a chain RIC (0#.FTSE) and then concurrently subscribe to items in that chain to retrieve TR.SharesHeldValue. The number of active requests at a time is controlled by Semaphore. The code sets a value of the semaphore to 20 so it will have 20 active requests at a time.
After running, it takes around 51 seconds to get TR.SharesHeldValue for 101 items. However, if I call the get_data method in sequence, it will take around 300 seconds to get TR.SharesHeldValue for 101 items. Concurrent requests are much faster than sequential requests.
Thanks @jirapongse.phuriphanvichai
This is very useful.
Hi @sunny.to
Please also make sure that the number of request and amount of data do not exceed the API limitation.
Thank you @ jirapongse.phuriphanvichai. It works in Jupyter notebook but fail to run in codebook with below error. do you know why?
RefiImportError: module 'os' is restricted.
@sunny.to
You can remove 'import sys,os,os.path' from the code.
It works when removed 'import sys,os,os.path' from the code.
thank you very much
