EMA - How do I reset view to get all fields?
I'm using EMA Java API. I use EmaFactory.createReqMsg().payload(view) to get a list of fields, how do I reset the view so that all fields could be returned? I've tried reissue(EmaFactory.createReqMsg(), handle), it doesn't seem to have any effect.
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apijava
11.5k 16 7 10
Hello @ahmire.kailer
I have a quick test with EMA Java 3.5.0 (ESDK 1.5.0L1) example360_view, the application can change a "set of fields" by create a new View payload as ElementList object and pass it to the OmmCosnumer.reissue() function.
However, if the application reissue with all field request message (example: _ommConsumer.reissue(EmaFactory.createReqMsg(), event.handle()); statement), the view subscription fields are unchanged.
I suggest you submit this issue to the ESDK Development team directly via ESDK GitHub Issue page. In the meantime, you workaround it by unsubscribing that item and re-subscribe it again as all fields request.
11.5k 16 7 10
This issue has been submit as issue #149 in GitHub.
