So I was running the RFA progarms in the examples and I had to use the RFA Configuration Editor to create the Connection and sessions as set in the tutorial.
My question is : what does the config editor do that enables the RFA applications to be read the correct configurations ? Is it updating the windows registry which are then read by the RFA api internally ? Is it setting up systems variables on my host ? I do not see any RFA system variables when I do a set command on my windows console.
Also , how do I use the editor on a server environment like Linux server ? There must be a way for exporting the config created by the editor in a windows host and directly feed the config file to an RFA application without requiring to use the Config Editor explicitly ?
