Using CF_Curr on companies listed on AMEX.
I was trying to request currency codes for companies listed under AMEX and I didn't succeed.
To use a couple of examples, when I used TSLA.O or 1111.HK, I got the currencies back correctly, but, when I tried using ISBC.A, I got nothing.
Is this normal?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonforex
@aquilesjlp300
To verify the problem, you can enable logging by using the following code:
import logging
logger = logging.getLogger('pyeikon')
logger.setLevel(5)
Then, run the code. You can verify the response message retrieved by the API.
18k 21 12 20
Hi @aquilesjlp300
It is working fine for me.
