I keep failing when I try to resolve a match with a long remark
error message like this
{ "error": "RESOLVE_RESULTS_FAILED", "cause": "Resolution of results request has failed, please check that all required fields are supplied and valid." }
so I try to make remark shorter, then the resolution succeed
May I know what is the size limit for the remark of resolution? could it be larger?
