Tick History Time and Sales data through Microsoft VBA, facing issue in downloading zipped files & mentioning file path for downloads.
The client is able to make it work for ‘smaller’ reports – e.g. a Terms and Conditions report, where the returned data is relatively small but not for a Tick History file, specifically around the downloading of Tick History where the files are zipped.
The client is following TRTHv2 API scheduled Workflow: using the ExtractedFIles(fileid)/$value method.
https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/ExtractedFiles('xxExtractedFileIdx')/$value
where my ExtractedFileID is ‘VjF8MHgwNzI5NjU1MzE1YzZiMGM2fA’ under ExtractionID ‘2000000162175976’.
This corresponds to the following schedule:
I can download the output file manually on the web interface, and I can download the corresponding Notes file via the API, but when I run the API GET against the main output – the zipped file - I get a ‘200-OK’ status but just a couple of odd characters in the response text:
I am using the ‘gzip, deflate’ option in my request:
Function download_full_file(FileDownloadURL As String, TRTHToken As String, FileExtractionID As String, FileDownloadStatus As String) As String
Dim objHTTP As New MSXML2.XMLHTTP
Dim FileDownloadURLwithID As String
Dim cutresponse As String
FileDownloadURLwithID = Replace(FileDownloadURL, "xxExtractedFileIdx", FileExtractionID)
objHTTP.Open "GET", FileDownloadURLwithID, False
objHTTP.setRequestHeader "Authorization", "Token " & TRTHToken
objHTTP.setRequestHeader "X-Direct-Download", "true"
objHTTP.setRequestHeader "Accept-Encoding", "gzip, deflate"
objHTTP.setRequestHeader "Accept-Charset", "UTF-8"
objHTTP.setRequestHeader "Prefer", "respond-async"
objHTTP.send
'InputBox "API Response - copy from below", "API Response", objHTTP.responseText
FileDownloadStatus = objHTTP.Status & " - " & objHTTP.statusText
download_full_file = objHTTP.responseText
End Function
Should I be expecting the files to be returned in the response text, or are they being physically downloaded somewhere for me to use?
tick-history-rest-apivbaDownload
11.3k 25 8 13
Hi @Beera.Rajesh,
The data extracted from TimeAndSales report template is in gzip format, so responseText contains binary gzip data. The client can write the response to a .gz file, and then decompress data from the .gz file outside of the application.
Below is the sample of code writing response to a .gz file.
        filePath = "C:\\temp\\response.gz"
        fileBytes = objHTTP.responseBody
        Open filePath For Binary As #1
        Put #1, , fileBytes
        Close #1
