Screening RICs with company names in R and Excel API
Hello, how do I screen RICs from a list of company in R or Excel? In R, it works well with one company name, but how to extend the query to 10,000 company names, for instance?
get_data(instruments = 'SCREEN(U(IN(Private(OrgType(COM,UNK,MKP)))),Contains(TR.CommonName,"AMNS Luxembourg Holding SA"))',fields=list("TR.CommonName"),debug =TRUE)
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythoneikon-com-apiscreening-apir
18k 21 12 20
Hi @asantos2
You can use OR operator on SCREENER syntax.
This is an example in Python: (For R you have to test it)
I do not know the maximum number of contain supported by SCREENER.
But I do not think that it can support all 10000 name at once.
Many thanks for your prompt response! However, how can I make a reference to a list of company names in Excel cells or a dataframe in R or Python instead of adding the term or Contains(TR.CommonName, "Company Name") in the query?
18k 21 12 20
Hi @asantos2
You can use SCREENER app to define a syntax.
https://developers.refinitiv.com/article/find-your-right-companies-screener-eikon-data-apispython
Then if it is in excel, you can list the company in your excel sheet.
And the formula can refer to your cell value in Excel.
In R or in Python, you can store the value in variables and when you pass the screener syntax to API call, you can refer to the variable value.
Many thanks. It works well in Python. I have also found out that you can download RICs in Excel with TR("SCREEN(U(IN(Private(OrgType(COM, UNK, MKP)))), Contains(TR.CommonName,'"&D3&"'))","TR.CommonName","RH=In TRANSPOSE:YES") and no double quotes in the company name in cell D3.
