I am trying to retrieve the daily stock prices from a certain stock. Below you can see my code. The problem is that on a certain day like weekend or holiday I am receiving the following error message which makes sense "NSUG.DE: No data available for the requested date range". Is there a possibility that I can ignore those days and my code does not run into an error?
#date modfication start_date = datetime(2020, 1, 1, tzinfo=timezone.utc) end_date = datetime(2020, 7, 10, tzinfo=timezone.utc) date_range = pd.date_range(start=start_date, end=end_date, freq='D') #RIC, fields, time to receive stock prices rics = ['NSUG.DE'] fields = ['OPEN','HIGH','LOW','CLOSE','VOLUME'] for date in date_range: sdate = str(date)[0:10] + 'T07:00:00' edate = str(date)[0:10] + 'T22:01:00' df = ek.get_timeseries(rics=rics, fields=fields, start_date=sdate, end_date=edate, interval='minute') print(df) #safe to csv df.to_csv('test' + str(date)[0:10] + '.csv')
