How can we convert 1000 PermIDs into rics?
What is the API to use?
What is the cost?
intelligent-tagging-apipermid-apiopen-permid-api
Not supported by DSS "Symbol Cross Reference", TRTH EBD files, nor PermID.org.
Is there a way to programatically convert PermID to any other identifier?
A fast way to convert them in Python is:
If you have a dataframe with PermIDs then you can extract the column for the PermIDs with:
df['Name Of The Column']
and follow the principle below:
### Extract the PermID from dataframe and convert it into a list of strings because ek.get_data takes in strings
ls_PermID = list(df['ame Of The Column'].astype('str'))
### Convert PermID to RIC with ek.get_data
ls_RIC, err = ek.get_data(ls_PermID, 'TR.RIC')
I just want to post this simple and efficient solution here after days of searching how to do it the best way.
1.2k 23 28 42
Create a "Terms and Conditions" report in DSS with "Issue PermID" and "RIC" fields. This will create a source data set for mapping RIC to PermID. Then you can feed this into your app or create a service that exports it through TREP, etc.
