Speed Guide (Error: Could not find or load main class com.thomsonreuters.ema.example.gui.SpeedGuide.SpeedGuide)
I have downloaded the Speed Guide but when I attempt to run the application on my mac I get the following error.
$ java -jar SpeedGuide.jar
elektronrefinitiv-realtimeelektron-sdkspeedguide
9.5k 10 5 7
Hello @john.ervine
SpeedGuide.jar is for Windows and Linux. This is mentioned in README.txt :
Please try to run on Windows or Linux.
I could run SpeedGuide.jar on Windows successfully as shown below:
Moreover, EMA Java used by SpeedGuide does not support Mac. Please refer to the API Compatibility Matrix which shows the environments that EMA Java supports.
I get the same error on Windows 10 (Version 1909 (OS Build 18363.1621)):
Z:\speedguide>java -jar SpeedGuide.jar
Error: Could not find or load main class com.refinitiv.ema.example.gui.SpeedGuide.SpeedGuide
Caused by: java.lang.NoClassDefFoundError: javafx/application/Application
Z:\speedguide>java --version
java 16.0.1 2021-04-20
Java(TM) SE Runtime Environment (build 16.0.1+9-24)
Java HotSpot(TM) 64-Bit Server VM (build 16.0.1+9-24, mixed mode, sharing)
Z:\speedguide>dir
10/23/2019 11:20 PM 5,041 keystore.jks
01/22/2021 06:07 PM 5,023 README.txt
06/22/2021 06:11 PM 92 speedguide.bat
04/19/2021 08:54 PM 349,184 SpeedGuide.exe
04/19/2021 10:00 PM 20,300,720 SpeedGuide.jar
