Quote RIC update visible on permid website, but not in bulk file or atom feed
On the web-site permid 1-21513114826 has RIC "BORD.OL", which is correct (the RIC recently changed from "BRGD.OL"). However in the latest bulk quotes file OpenPermID-bulk-quote-20200705_132936.ntriples.gz the RIC has the old value:
<https://permid.org/1-21513114826> <http://permid.org/ontology/financial/hasRic> "BRGD.OL"^^<http://www.w3.org/2001/XMLSchema#string> .
I downloaded the quote updates from the RSS feed, and there are no updates for this permid, so nothing showing that the RIC changed. Is the RSS feed incomplete? When I downloaded from the RSS feed there were 416 entries with update times from 2020-07-06T15:15:58Z to 2020-07-08T06:19:03Z. It looks like there is a gap between the time of the bulk file (20200705_132936) and the oldest entry
<entry>
<title>WHITEBARK ENERGY ORD G</title>
<link href="https://permid.org/1-21757667192" />
<id>https://permid.org/1-21757667192</id>;
<updated>2020-07-06T15:15:58Z</updated>
Did you have an outage resulting in missing entries in the RSS feed?
ricsintelligent-tagging-apipermid-apiopen-permid-apibulk-download
@duncan.sands
I have checked the latest file OpenPermID-bulk-quote-20201101_044347.ntriples.
The RIC of 1-21513114826 is BORD.OL.
<https://permid.org/1-21513114826> <http://permid.org/ontology/financial/hasRic> "BORD.OL"^^<http://www.w3.org/2001/XMLSchema#string> .
Could you please confirm that the problem has been solved?
@duncan.sands
Yes, you are correct.
The OpenPermID-bulk-quote-20200705_132936.ntriples file contains BRGD.OL for 1-21513114826:
The website 1-21513114826 shows BORD.OL.
However, the quote atom feed doesn't have this change.
 <link rel="self" href="https://api-eit.refinitiv.com/permid/atom/quote?offset=0&amp;length=486" />
    <link rel="first" href="https://api-eit.refinitiv.com/permid/atom/quote?offset=0&amp;length=486" />
    <link rel="last" href="https://api-eit.refinitiv.com/permid/atom/quote?offset=0&amp;length=486" />
    <author>
        <name>PermID</name>
        <uri>https://permid.org</uri>
    </author>
    <subtitle>From date(UTC) : 2020-07-04T03:43:35.000Z, To date(UTC) : 2020-07-09T03:43:34.000Z, Window : Offset = 0, Length = 486, out of 486 results.</subtitle>
I will contact the PermID team to verify this issue.
