Possible to change the way Eikon sends : ApplicationAuthorizationToken?
Hello, when Eikon starts up, it sends multiple messages to the ADS, one of which contains the attribute : ApplicationAuthorizationToken, of which the containing data is of type "Buffer". Do you know if this can be changed to type "Ascii" instead?
eikonelektronrefinitiv-realtimeelektron-sdk
@anish.pancholi
This forum is dedicated to software developers using Refinitiv APIs. Your question is about Eikon configuration. It would be best addressed to Refinitiv Helpdesk via MyRefinitiv. To the best of my knowledge there's no way to configure Eikon to use a different type in ApplicationAuthorizationToken. However you may want to verify this with Refinitiv Helpdesk.
