What is the format for a deep link to workcheck.refinitiv.com that includes the case system id
We have been using direct URLs into Accelus Worldcheck one for specific cases, such as:
https://app.accelus.com/#accelus/fsp/%7B%22location%22%3A%22%3Flocale%3Den-US%23fsp%2Fcase%2F{ {SYSTEM_CASE_ID}}%2Fview%2Fworldcheck%22%7D
But have been asked to start using the following by our client (due to a change of authenication system).. can someone please confirm the path and query string format to use the achieve the equivalent deep link after the worldcheck.refinitiv.com at the end of:
https://amers1.login.cp.thomsonreuters.net/auth/UI/Login?epaid=**************************************&product=custom&theme=charcoal&goto=https%3A%2F%2Fsts.login.cp.thomsonreuters.net%2Foauth2%2Fv1%2Fauthorize%3Fclient_id%3D**************************************%26response_type%3Dcode%26scope%3Dtrapi%26state%3D0.9999380129640164%26redirect_uri%3Dhttps%3A%2F%2Fworldcheck.refinitiv.com
Thanks.
world-checkworld-check-onescreeningauthenticationdeep-link
4.5k 4 7 8
Hi @dev78,
Thank you for your query.
Please use the below format to construct your URL - https://worldcheck.refinitiv.com/#accelus/fsp/%7B%22location%22%3A%22%3Flocale%3Den-US%23fsp%2Fcase%2F{ {SYSTEM_CASE_ID}}%2Fview%2Fworldcheck%22%7D
Please note : The base URL will be updated, the URL schema remains the same.
Hope this answers your query.
