streaming_prices.open()
HI i have the following code:
def display_refreshed_fields(streaming_price, instrument_name, fields): current_time = datetime.datetime.now().time() print(current_time, "- Refresh received for", instrument_name, ":", fields) def display_updated_fields(streaming_price, instrument_name, fields): current_time = datetime.datetime.now().time() print(current_time, "- Update received for", instrument_name, ":", fields) def display_status(streaming_price, instrument_name, status): current_time = datetime.datetime.now().time() print(current_time, "- Status received for", instrument_name, ":", status) streaming_prices = ek.StreamingPrices( instruments = ['EUR=','GBP=','JPY=', 'CAD='], fields = ['SALTIM', 'CF_BID','CF_ASK','OPEN_PRC', 'CF_HIGH','CF_LOW', 'CF_CLOSE'], on_refresh = lambda streaming_price, instrument_name, fields : display_refreshed_fields(streaming_price, instrument_name, fields), on_update = lambda streaming_price, instrument_name, fields : display_updated_fields(streaming_price, instrument_name, fields), on_status = lambda streaming_price, instrument_name, status : display_status(streaming_price, instrument_name, status) ) streaming_prices.open()
I use Pycharm and running this code i get:
16:20:03.342917 - Status received for GBP= : {'status': <StreamState.Open: 3>, 'code': 'Open', 'message': 'All is well'} 16:20:03.343917 - Refresh received for GBP= : {'CF_BID': 1.2503, 'CF_ASK': 1.2507, 'OPEN_PRC': 1.2473, 'CF_HIGH': 1.2529, 'CF_LOW': 1.2462, 'CF_CLOSE': 1.247} 16:20:03.343917 - Status received for JPY= : {'status': <StreamState.Open: 3>, 'code': 'Open', 'message': 'All is well'} 16:20:03.343917 - Refresh received for JPY= : {'CF_BID': 107.5, 'CF_ASK': 107.53, 'OPEN_PRC': 107.45, 'CF_HIGH': 107.72, 'CF_LOW': 107.34, 'CF_CLOSE': 107.46} 16:20:03.343917 - Status received for CAD= : {'status': <StreamState.Open: 3>, 'code': 'Open', 'message': 'All is well'} 16:20:03.343917 - Refresh received for CAD= : {'CF_BID': 1.3576, 'CF_ASK': 1.358, 'OPEN_PRC': 1.3582, 'CF_HIGH': 1.3611, 'CF_LOW': 1.356, 'CF_CLOSE': 1.3585} 16:20:03.343917 - Status received for EUR= : {'status': <StreamState.Open: 3>, 'code': 'Open', 'message': 'All is well'} 16:20:03.343917 - Refresh received for EUR= : {'CF_BID': 1.1264, 'CF_ASK': 1.1268, 'OPEN_PRC': 1.125, 'CF_HIGH': 1.1302, 'CF_LOW': 1.1248, 'CF_CLOSE': 1.125} Process finished with exit code 0
As you can see, the program terminates almost immediatly, I would like the streaming prices to keep open and the updates getting handled when they come in.
What works is putting the streaming_prices.open() in a loop:
while True:
while True:
pass
this doesnt work either unfortunatly, then the program doesnt terminate, but the updates dont get handled by the function.
But I cant imagine this is the way to do it? Any help would be appreciated, thanks!
Jan
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonstreaming-prices
4.3k 2 4 5
streaming_prices.open() does just the streaming connection with the server.
It's up to you to keep it streaming the duration you want/need.
The solution you propose is correct but you should define the way to stop it
while True:
if <condition is True>:
break
You can also run your code in a Jupyter notebook because the stream will continue until you close your book.
somehow the readability got lost, here is the code again:
that is clear then, thank you Pierre!
