Using Elektron API seeing data as of 19th June for few Lipper RIC
RICS:
LP40001481
LP40071600
LP60004185
LP60052825
LP65010917
LP65098435
LP65107123
LP68020134
LP68028847
LP68085367
LP68119589
LP68161769
LP68229471
LP68556142
field id :
11 21 6 22 25 19 32 16 12 13 118 0
elektronrefinitiv-realtimeelektron-sdk
Hello @debashish.bisoi,
You appear to be using Elektron API ( EMA? ETA? Websockets?) to consume Elektron realtime content?
If it's on realtime content, is your question that you do not see the updates from the instruments?
If correct, please test with the simplest consumer example included with your Elektron SDK (you do not state what language option you use) to verify that the issue is not specific to your custom app.
For sanity check, I just subscribed LP40001481 and the last update to TRADE_FAET field was on June 29th.
Hi Zoya
Just heard back from Refinitiv support , this is actually a problem with Refinitiv upstream device cc2p-ddnbads06a since the same request with Lipper ric return correct data when we switch to the back up servers we have in place which point to a different Refinitiv upstream host cc1p-ddnbads04a
Attaching the request and response file tre10629.zip
tre10629.zip (747 B)
HI Zoya
it works fine for every other RIC , for eg /IBM.N gives me data as of today but only these RIC give data as of 19th JUne
23k 22 9 14
In this case, my thinking is in a totally different direction. If when testing with a simple standard example, that came with your API SDK, for example, for EMA it's Example100_MarketPrice, (are you testing with a standard example or with a custom consumer app?) /IBM.N updates and LP40001481 does not,
Then the issue is likely not in the API, as with standard example testing, correct API usage is 100% assured.
And from the API usage standpoint consuming /IBM.N is exactly identical to consuming LP40001481 .
The issue is likely with permissioining for Lipper. /IBM.N is a delayed IBM, and is in many cases just permissioned as part of entitlements package, I suspect this may be true in your case. Lipper RICs are not available as "/" and have to be permissined separately.
Please contact your Refinitiv account manager, to confirm, that your user id is permissioned for Lipper content from Elektron.
