I have some problems using Datastream via python. I'm trying to connect to Datastream using the sample code with python code:
import DatastreamDSWS as DSWS ds = DSWS.Datastream(username='NN', password='XX') ds.get_data(tickers='VOD', fields='P', kind=0)
Using my correct username and password yields:
Exception: Invalid Token Value
_get_token : Exception Occured
(<class 'ModuleNotFoundError'>, ModuleNotFoundError("No module named 'wincertstore'"), <traceback object at 0x000002316A8F8248>)
None
get_data : Exception Occured
(<class 'Exception'>, Exception('Invalid Token Value'), <traceback object at 0x000002316A8B1848>)
None
The test web page http://product.datastream.com/DswsClient/Docs/TestSoapV1.aspx yields a valid results.
My python venv list is:
Python version is 3.7.6.
Does anyone know how I can this working?
Thank you for your help.
