Adelaide Brighton Ltd has changed its name
ADELAIDE BRIGHTON LIMITED (https://permid.org/1-4295857193) has changed its name to ADBRI LIMITED on 25/05/2020 but this is not reflected on permid.org
intelligent-tagging-apipermid-apiopen-permid-api
@david.snowsill
Yes, you are correct.
When I use Entity Search to search for "ADBRI LIMITED", it returns the correct PermID.
          "@id": "https://permid.org/1-4295857193",
          "organizationName": "Adbri Ltd",
          "primaryTicker": "ABC",
          "orgSubtype": "Company",
          "hasHoldingClassification": "publiclyHeld",
          "hasURL": "http://adbri.com.au/"
However, when using the Look Up, it returns the old name.
<https://permid.org/1-4295857193>
        a                               tr-org:Organization ;
        tr-common:hasPermId             "4295857193"^^xsd:string ;
        tr-fin:hasOrganizationPrimaryQuote
                <https://permid.org/1-55835568425> ;
        tr-fin:hasPrimaryInstrument     <https://permid.org/1-8590926468> ;
        mdaas:HeadquartersAddress       "L 1 157 Grenfell Street\nADELAIDE\nSOUTH AUSTRALIA\n5000\nAustralia\n"^^xsd:string ;
        mdaas:RegisteredAddress         "L 1 157 Grenfell Street\nADELAIDE\nSOUTH AUSTRALIA\n5000\nAustralia\n"^^xsd:string ;
        tr-org:hasActivityStatus        tr-org:statusActive ;
        vcard:organization-name         "Adelaide Brighton Ltd"^^xsd:string .
I will contact the Open PermID team to verify it.
