StreamingPrices run forever
I'm using the Eikon Data API and trying to get streaming prices working from a script (not jupyter). I'm using the example code provided on PyPI and on github (in a script form). Currently the streaming_prices.open() receives updates and refreshes for the specified instruments and then almost immediately completes and ends the script. Is there a way to run a StreamingPrices instance "forever" and use the callbacks to evaluate realtime data?
Cheers
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonstreaming-prices
Hi @airxhi
You can try something like
streaming = ek.StreamingPrices(....)
streaming.open()
asyncio.get_event_loop().run_until_complete(asyncio.sleep(60))
streaming.close()
where the above will open the stream, run for 60 seconds before closing the stream.
If you want to run forever you can put the asyncio call in a continuous loop?
Hi Umer,
That's exactly what I was looking for, thanks!
Kind Regards
