Eikon API Proxy stopped working on MacOS
In the last three days I've having problems with the Eikon API Proxy on my Macbook Pro. I run the proxy and it shutdown after a few seconds. I tried reinstalling it and reseting cache by Terminal, but that didn't work. After I log in, it shuts down again.
I'm running MacOS 10.15.5 and I didn't updated the OS or installed new applications last days.
I attach my logs to show you the last try to run the API Proxy.
browser_1532.20200622.log.zip
I'll appreciate your help.
Thanks!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonmac-os
From the log you provided, Eikon API Proxy fails to download the configuration from Eikon platform. One reason this could happen is invalid Eikon user credentials. I checked the email address you used to register on this portal and it doesn't seem to be associated with any Eikon user accounts. Did you perhaps have a trial of Eikon, which expired? I suggest you verify Eikon user account you're using by logging in to Eikon Web: http://eikon.thomsonreuters.com/login
