On changing the value of XMLTRaceStdOut in configuration file from 0 to 1 the application crashes.
<XmlTraceToStdout value="1"/>
Something like below error print on console
Thank-you!
Thank-you!
Hello @MayassK
This is not the error but it is field id(FID) 935 definition in a dictionary response received from the server where EMA requests dictionary from(default behavior). I also got the same message as you.
Dictionary request sent from EMA(Outgoing Reactor message)
<!-- Outgoing Reactor message --> ... <REQUEST domainType="DICTIONARY" streamId="3" containerType="NO_DATA" flags="0x06 (HAS_PRIORITY|STREAMING)" priorityClass="1" priorityCount="1" dataSize="0"> <key flags="0x0B (HAS_SERVICE_ID|HAS_NAME|HAS_FILTER)" serviceId="4515" name="RWFFld" filter="7"/> <dataBody> </dataBody> </REQUEST>
Dictionary response received from the server(Incoming Reactor message)
<!-- Incoming Reactor message --> ... <REFRESH domainType="DICTIONARY" streamId="3" containerType="SERIES" flags="0x168 (HAS_MSG_KEY|SOLICITED|REFRESH_COMPLETE|CLEAR_CACHE)" groupId="0" State: Open/Ok/None - text: "" dataSize="616032"> <key flags="0x0B (HAS_SERVICE_ID|HAS_NAME|HAS_FILTER)" serviceId="4515" name="RWFFld" filter="7"/> <dataBody> ... <seriesEntry> <elementList flags="0x02 (HAS_SET_DATA)"> <elementEntry name="NAME" dataType="ASCII_STRING" data="SLOT_AAFLG"/> <elementEntry name="FID" dataType="INT" data="935"/> <elementEntry name="RIPPLETO" dataType="INT" data="0"/> <elementEntry name="TYPE" dataType="INT" data="5"/> <elementEntry name="LENGTH" dataType="UINT" data="1"/> <elementEntry name="RWFTYPE" dataType="UINT" data="19"/> <elementEntry name="RWFLEN" dataType="UINT" data="1"/> <elementEntry name="ENUMLENGTH" dataType="UINT" data="0"/> <elementEntry name="LONGNAME" dataType="ASCII_STRING" data="SLOT AAFLG"/> </elementList> </seriesEntry> ...
If EMA requests data successfully, you will see the following messages:
Data requests example message:
<!-- Outgoing Reactor message --> ... <REQUEST domainType="MARKET_PRICE" streamId="5" containerType="NO_DATA" flags="0x46 (HAS_PRIORITY|STREAMING|HAS_QOS)" Qos: Realtime/TickByTick/Static - timeInfo: 0 - rateInfo: 0 priorityClass="1" priorityCount="1" dataSize="0"> <key flags="0x03 (HAS_SERVICE_ID|HAS_NAME)" serviceId="4515" name="PTT.BK"/> <dataBody> </dataBody> </REQUEST>
Data Response example message:
<!-- Incoming Reactor message --> ... <REFRESH domainType="MARKET_PRICE" streamId="5" containerType="FIELD_LIST" flags="0x1FA (HAS_PERM_DATA|HAS_MSG_KEY|HAS_SEQ_NUM|SOLICITED|REFRESH_COMPLETE|HAS_QOS|CLEAR_CACHE)" groupId="1" seqNum="55232" permData="0311 A367 61C0" Qos: Realtime/TickByTick/Static - timeInfo: 0 - rateInfo: 0 State: Open/Ok/None - text: "All is well" dataSize="1385"> <key flags="0x07 (HAS_SERVICE_ID|HAS_NAME|HAS_NAME_TYPE)" serviceId="4515" name="PTT.BK" nameType="1"/> <dataBody> <fieldList flags="0x09 (HAS_FIELD_LIST_INFO|HAS_STANDARD_DATA)" fieldListNum="2" dictionaryId="1"> <fieldEntry fieldId="1" data="1A69"/> <fieldEntry fieldId="2" data="8E"/> <fieldEntry fieldId="3" data="5054 54"/> ...
Thank you Pimchaya.Wongrukun,
Is there any way to see server logs in application?
As mentioned in tutorial XMLTraceOut is used to see the logs but i am getting above response and after this response i am not able to execute the batch.
Thanks for your help!
Hello @MayassK
There is no way to see server logs in the application. To send batch request, please try example370__MarketPrice__Batch.
Hi @MayassK
If you wish to capture / redirect the XMLTrace to a file please see the following post on redirecting to a file:
How to enable tracing incoming/outgoing messages EMA Java receives/sends
