TREP ADH Delayed Feed "Data BLOCK" message on ric subscription
This query is in regards to the delayed feed (dELEKTRON) on the TREP infrastructure.
I am noticing "DATA BLOCK" message on subscribing LME Exchange instruments e..g.rics "MALD31N0=LX" ; "MZND26M0" through the delayed service however there are no issues when subscribing the same instruments on the live feed (ELEKTRON_DD). Refinitiv support (case 08803859) advised that LME Exchange data is not available via the delayed feed.
So wanted to check on this forum whether has anyone experienced such a similar issue and if there is any possible solution or a workaround to get the "DATA BLOCK" issue fixed.
Thanks,
Sunil
elektronrefinitiv-realtimetrepinfrastructureADHdelayed-feed
The DELAY DACS config can be seen in DACS Reference section F3.4.1.
Note that you must put DELAY as a Concrete Service under IDN. This will then use the MCA_IDN and feed up to AAA
TR - please provide an example rmds.cnf > ADH config for FEELIABLE. ADH install guide section 15.3.1 is not clear on this
The default NON-FEELIABLE will of course only provide images for exchanges where there are no fees
@Sunil.Annaldasula
@Kevin.Gower
This developer forum is for questions on and general discussions of Refinitiv APIs.
For TREP questions, the best and most efficient way to receive answers is to open a technical inquiry via MyRefinitiv, or to call the Refinitiv Help Desk directly.
