Hi! I want to download bulk data for banks eg. ROA for all commercial banks in the US between 2010-2019. Is there any way using EIKON? Or simply I have to select a bank then to searach on the financials and to download at bank level? Thank you
eikoneikon-com-apieikon-for-office
You can use Screener to search for companies based on your set of criteria, e.g. headquartered in the US and falling under Banking Services TRBC Industry Group. When setting up the Screener expression you can specify that you want to retrieve ROA for fiscal years 2010 - 2019. For more details on using the Screener see the article titled "Find Your Right Companies with SCREENER" on this portal. There are also training materials on using the Screener in Eikon Help.
