Is it possible to refine search for World-Check Screening using custom fields.
I was trying to use a custom field to refine my search but do not see that it's using it in the search. I added -BUSINESS REGISTRATION NUMBER (UEN in singapore context) and was trying to test it. I searched for singapore airlines with "197200078R" as business registration number but it still shows two results.
Could you please suggest what I could be doing wrong here. Thanks.
world-checkworld-check-one
4.5k 4 7 8
Hi @Vini,
Thank you for your query.
The reason you are seeing 2 results is because custom fields are not included in screening.
Hope this clarifies your concern.
Thanks @Prabhjyot.Mandla. So I believe there is no other way of refining the results other than registered country in this case?
@Vini,
As of now, there is no other way to refine results for an organisation other than country code. You may use the custom field for your reference in the case.
Hope this helps.
Sure. Thanks @Prabhjyot.Mandla.
