TIBCO Error under RFA API
Hi, Currently, I use old RFA API library on Java swing to retrieve delayed CHF overnight rate by /SARON.S RIC code. I got error message " TIBCO exception.Unable to unpack data with TibMsg". I looks that Refinitiv (Thomson Reuters) infrastructure by ( TREP-RT (ADS) & RFA API ) does not support this feature. I will be very happy if I get any solution for this error.
treprfarfa-api
9.5k 10 5 7
Hello @Yong.Kim
RFA API is a feature-completed API. I recommend you migrate to Elekton Message API (EMA Java API) which is a part of the Elektron SDK family. Please refer to Why Migrate from RFA to EMA API? VDO which shows how migrating from RFA Marketdata interfaces which you are using to EMA, The VDO also mention the benefits of EMA. For more details of EMA Java, please refer to Elektron SDK – Java Page.
