How can I enable the logging for ticker subscription in ADS and ADS
Hi Team, I would like to find out when ADS receives the ticker subscription from users during the day. Would you help to advise if there is a logging that I can enable to log the ticker subscription request in ADS and ADH?
We are on TREP 2.6
elektronrefinitiv-realtimetrepinfrastructureADSADH
11.5k 16 7 10
Hello @nikita.ou
You can use the TREP dumpIncoming parameter to let TREP logs messages received for all channels owned by the route to the binary debug log file. Then you can use TREP dbgLogMon to translate the binary debug log file to a readable text format. This parameter logs all of incoming messages so it will impact the TREP performance.
I highly recommend you contact the TREP support team via https://my.refinitiv.com/ web site to help you find better way(s) that match your requirement.
