MS Office Excel 365 - API - AdfinX Real Time 6.0 Library for Windows 10
Team,
Our existing Realtime Refresh in Excel 2007 VBA code is not working in Win10 Office 365 environment because EIKON API - "AdfinX Real Time 6.0 Library " is not compatible with Win10 Office 365.
May I please except a resolution for this? help much appreciated
We are trying to fetch 02 types of requests:
  1. Refintiv Static data page (E.g. RIC page - "PULF" , Bostwana Govt bonds):
Snippet:
Dim rtList As AdfinXRtLib.AdxRtList
Set rtList = PLVbaApis.CreateAdxRtList
rpage="PULF"
rtList.Source = "IDN": rtList.RegisterItems rpage, "*"
rtList.StartUpdates RT_MODE_IMAGE
2. Refintiv realtime RIC fields (E.g. RIC page - "HICNH1MDF=ABCK" , HIBOR CNH submission):
Snippet:
Dim fields(2) As Variant: fields(0) = CF_BID: fields(1) = CF_DATE: fields(2) = CF_TIME
ric_ticker = "HICNH1MDF=ABCK"
rtList.Source = "IDN": rtList.RegisterItems ric_ticker, fields
Sandeep
eikoneikon-data-apieikon-com-api
Did you try to reset macro and change AdfinX reference(Tools->references)?
@sandeep.kola
AdfinX Real-Time 6.0 library is perfectly compatible with Windows 10 and Office 365 32-bit. I personally use it all the time in this environment. However Eikon COM APIs libraries including AdfinX Real-Time cannot be used in 64-bit Excel VBA. If you have 64-bit MS Office, the only option to continue using AdfinX Real-Time library in Excel VBA is to replace your 64-bit Office install with 32-bit one.
Yes, I've tried and no luck, I'm pretty sure EIKON API - "AdfinX Real Time 6.0 Library " is not compatible with Excel 365 version
Do you use 32bit excel? Can you give us error message content or run-time error number? Did you test other AdfinX versions? You can look for rtx.dll in eikon installation directory.
Hello @sandeep.kola
Did you have a change to test the steps that suggested by @SupDev1 ?
