Elektron WebSocket API - Explicity send Logout message?
I've been reviewing the documentation for the Elektron WebSocket API. When using the API do I need to explicitly send a 'Logout' message? Or does the API logout if a user's connection is lost/doesn't recieve a ping?
treprdp-apiwebsocketsrrto
I'm referring to this message that's document in the API. The 'Close' Messsage for Login:
        "Domain":"Login",
        "ID": -1,
        "Type":"Close"
Hi @jonathan.powell,
The infrastructure will automatically logout the user if the connection is terminated. It will also terminate the connection, if the reply to ping message is not received.
