Best practice for accessing known fields
I am migrating from TibMsg to OMM. Our application just needs numerical data (e.g. BID, ASK). So being new to OMM I would like you advice.
  1. Is there a more direct method to get fields?
  2. Considering that I know the field and data type in advance, is the code below too defensive? Not defensive enough?
public void processEvent(Event event) {
  if (event.getType() == Event.COMPLETION_EVENT) {
    log.info("Receive a COMPLETION_EVENT, "+ event.getHandle());
    return;
  if (event.getType() != Event.OMM_ITEM_EVENT) {
    log.warning("Received an unsupported Event type.");
    mainApp.disconnect();
    return;
  OMMItemEvent ie = (OMMItemEvent) event;
  OMMMsg respMsg = ie.getMsg();
  if (respMsg.getDataType() != OMMTypes.NO_DATA) {
    OMMData ommPayload = respMsg.getPayload();
    if (ommPayload.getType() == OMMTypes.FIELD_LIST) {
      OMMFieldList ommFieldList = (OMMFieldList) ommPayload;
      int dictId = ommFieldList.getDictId();
      FieldDictionary fd = GenericOMMParser.getDictionary(dictId);
      for (Iterator<OMMEntry> it = ommFieldList.iterator(); it.hasNext(); ) {
        OMMEntry ommEntry = it.next();
        if (ommEntry.getType() == OMMTypes.FIELD_ENTRY) {
          OMMFieldEntry ommFieldEntry = (OMMFieldEntry) ommEntry;
          FidDef fidDef = fd.getFidDef(ommFieldEntry.getFieldId());
          String field = fidDef.getName();
          if (field.equals("BID") || field.equals("ASK")) {
            OMMData actualData = ommFieldEntry.getData(fidDef.getOMMType());
            double d = ((OMMNumeric) actualData).toDouble();
            System.out.printf("Field [%1$s] Value [%2$f]\n", field, d); }
          } // field_entry
       } // iterator
     } // field list
  } // no_data
treprfarfa-api
If not using a "dynamic view" one can see a performance improvement by breaking out from the field enumeration once all desired fields have been extracted.
I've tried the code and it worked well. This is a typical and direct way to retrieve fields in OMM so I don't think there is a more direct way for this. And, I don't see any need to perform further defensive type checking - it was sufficient for the task.
