TREP API error
Error is it on TREP parameter or API config parameter?
2020 May 11 16:19:45.674 ST GMT+08:00 1B2D F802E8C0 1283 ERROR*
<- Received MMT_MARKET_PRICE Status
serviceName : IDN_RDF
symbolName : 8287.HK
streamState : Closed
dataState : Suspect
statusCode : TooManyItems
statusText : A20: Aggregate item limit exceeded. received invalid item data from server
********************** INFO ************************ INFO **********************
2020 May 11 16:19:45.674 ST GMT+08:00 1B2D F802E8C0 916 INFO
<- Received Event Stream Closed Event, event type: OMMItemEventEnum handle: 0x2aaaacb39010, 8287.HK
********************* ERROR! ********************** ERROR! *********************
symbolName : 8290.HK
dataState : Suspect
<- Received Event Stream Closed Event, event type: OMMItemEventEnum handle: 0x2aaaacb393a0, 8290.HK
symbolName : 8291.HK
dataState : Suspect
<- Received Event Stream Closed Event, event type: OMMItemEventEnum handle: 0x2aaaacb39730, 8291.HK
symbolName : 8292.HK
dataState : Suspect
<- Received Event Stream Closed Event, event type: OMMItemEventEnum handle: 0x2aaaacb39ac0, 8292.HK
symbolName : 8293.HK
dataState : Suspect
elektronrefinitiv-realtimetrepinfrastructure
7.6k 15 6 9
Thanks a lot, we have modified the parameter to 25000 and reboot ADS, but still not working. Do we need to restart upstream like EED as well? @moragodkrit
I would suggest you contact TSG/ADS support to verify your setting and investigate issue further.
