How to solve Prebuilt libraries not found
I am trying to build the EMA/ETA SDK C++ when I get the following error
Prebuilt libraries not found: librssl_LIBRARY_OPTIMIZED-NOTFOUND, in
./Elektron-SDK-1.5.0.L1.linux/setup/Elektron-SDK-1.5.0.L1.linux.rrg/Cpp-C/Eta/Libs/UBU18_64_GNU750/Optimized;/home/hakan/Downloads/Elektron-SDK-1.5.0.L1.linux/setup/Elektron-SD
Would appreciate som help
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apic++
solved by simply downloading source code from github and follow instructions
could you please help paste the git link? I had the same problem when try to copile the SDK. Thx
