Is there any cost involve to increase the aggregate item limit. For example if the current Aggregate item limit is set to 9600 and i want to increase it to 15K or 20K. Will there be any cost ? Appreciate if anyone can help to provide the details.
Hello @Amit1627
The aggregate item limit value is based on TREP's aggregateItemLimit parameter. I suggest you contact the TREP support team via https://my.refinitiv.com/ to help you verify the impact of increasing this parameter value in your TREP.
Hello @Amit1627
Have you contacted Refinitiv account team yet? The team should be able to provide this info with you.
Why do you want to increase the Aggregate item limit? Do you receive the error A20: Aggregate item limit exceeded?
