Reissue command timer expired
Dear Team
cfg file
# send unique attrib info with each request.
# This flag can be used to make a the same item (For example: IBM.N) look unique when sent in multiple requests
# the provider displays this info when the flag is set to true
sendAttribInfo = false
batchReissueList = "SGD=,JPY="
batchCloseList = "IBM.N"
batchReissueTime = 20
batchCloseTime = 30
********************** INFO ************************ INFO **********************
2020 May 06 12:24:03.678 ST GMT+08:00 1E50 1F64 1234 INFO
batchReissueTime = 20 seconds has expired - batchReissueList = {SGD=, JPY=, }.
2020 May 06 12:24:03.678 ST GMT+08:00 1E50 1F64 1376 INFO
itemMap contains:
[0] 03087870 0 0 EUR=
[1] 03086B60 1 1
[2] 03086DC0 1 0 SGD=
[3] 03086A30 1 0 JPY=
[4] 03087740 2 1
[5] 03086C90 2 1 IBM.N.
2020 May 06 12:24:03.678 ST GMT+08:00 1E50 1F64 1239 INFO
Sent Batch Reissue for the following 2 item handles:
[2] 03086DC0 SGD=
[3] 03086A30 JPY=
timer will NOT be reset.
Above log tried to reissue and timer got expired
Kindly check
treprfarfa-api
Hello @harik
Thank you for your participation in the forum. Is the reply below satisfactory in resolving your query?
If so please can you click the 'Accept' text next to the appropriate reply. This will guide all community members who have a similar question.
Thanks,
AHS
Hi @harik
Please advise what you wish to check?
In your config, you have set the optional batchReissueTime value - which means the example will perform a Batch Reissue and then the timer will not reset.
If you refer to the code you can see this is what the example is designed to do.
Please advise what it is you are trying to test - I recommend you refer to the README.txt file in the example folder which describes the example application in some detail.
