Is the C SDK for 64bit Linux (CentOS) available?
Background:
We are porting old legacy code from Solaris 32bit to Linux 64bit. This application contains the old Reuters ssl implementation on Solaris 32bit OS. Hence, we are looking for C SDK in 64Bit for CentOS.
Details:
Below is the function extract from our old ssh.h
extern int sslDismount SSL_ARGS((int Channel));
extern int sslDispatchEvent SSL_ARGS((int Channel, int MaxEvents));
extern int sslErrorLog SSL_ARGS((char *LogFileName, int LogFileSize));
extern char *sslGetErrorText SSL_ARGS((int Channel));
extern int sslGetProperty SSL_ARGS((int Channel, SSL_OPTION_CODE OptionCode,
void *OptionValue));
extern int sslInit SSL_ARGS((int VersionNo));
extern int sslMsgClose SSL_ARGS((int Channel, char *ProtocolName,
char *FilterString));
extern int sslMsgMount SSL_ARGS((char *UserName, ...));
extern int sslMsgOpen SSL_ARGS((int Channel, char *ProtocolName,
char *FilterString, void *ClientItemTag, ...));
extern int sslPostEvent SSL_ARGS((int Channel, SSL_EVENT_TYPE EventType,
SSL_EVENT_INFO *EventInfo));
extern int sslRegisterCallBack SSL_ARGS((int Channel, SSL_EVENT_TYPE EventCode,
SSL_EVENT_RETCODE (*Event_Function)(int, SSL_EVENT_TYPE,
SSL_EVENT_INFO *, void *), void *ClientEventTag));
extern int sslRegisterClassCallBack SSL_ARGS((int Channel,
SSL_EVENT_CLASS_TYPE EventCode,
extern int sslSetProperty SSL_ARGS((int Channel, SSL_OPTION_CODE OptionCode,
extern int sslSnkClose SSL_ARGS((int Channel, char *ServiceName,
char *ItemName));
extern int sslSnkMount SSL_ARGS((char *UserName, ...));
extern int sslSnkOpen SSL_ARGS((int Channel, char *ServiceName, char *ItemName,
extern int sslSrcMount SSL_ARGS((char *UserName, char *ServiceName,
int CacheSize, ...));
extern int sslSrcReady SSL_ARGS((int Channel));
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonelektron-sdk
@shiva.kumar
From the function names, you are using SSL API.
  • SSL Classic 4.0 API has been end-of-life since 31 May 2013
  • SSL 4.5 API has been end-of-life since 30 June 2015
We don't support SSL API anymore. Moreover, there is no 64-bit version of SSL API.
The migration path is the Elektron SDK (ETA) which is available at https://developers.refinitiv.com/elektron/elektron-sdk-cc. Refer to the API Compatibility Matrix, ETA C supports Centos 7.0 64-bit.
