GOVSRCH using COM API
How can I run something similar using COM API?
RIC sample: ANVHA.AX
I cannot get it using RSearch COM API or Excel.
eikoneikon-data-apieikon-com-api
I'm having the same issue with Hong Kong : 4427.HK
@igorg
I don't think I'm following what you're trying to do. Are you asking what criteria you could use to retrieve these bonds with RSearch? Here's an example of RSearch Excel worksheet function that returns SG095378323=, which is the primary RIC for ANVHA.AX.
=RSearch("BOND","RawContextFilter:'DbType eq \'CORP\' and IsActive eq true' IssuerOrgid:'100651023' MaturityDate:<2020-08-01")
I'm trying to get all RICs
Your sample returns : SG095378323=
I want to get ANVHA.AX
I'm still not following. Would you mind elaborating on what you're looking to achieve? Are you trying to get all RICs for a given bond? Then you shouldn't use RSearch. RSearch serves the use case when you're looking for a list of instruments based on a criteria (e.g. all bonds issued by companies domiciled in a given country and with maturity dates between X and Y). RSearch returns one identifier per instrument. If you're looking to get all RICs for a given bond use DEX2 library with the field TR.RICS. Or in Excel use
=TR("SG095378323=","TR.RICS")
I'm trying to get all RICs for Australia and Hong Kong for all Asset Types.
For equities and funds I use RSearch COM API with RIC = '*.AX'. But they do not return me bonds. If I use AssetType = 'BOND' I still do not receive those RICs: 4401.HK,4402.HK, 4403.HK, 4404.HK, 4405.HK... They are Fixed Income type. I don't know what to use in AssetType to get them.
