MATUR_DATE not found for XAUID=
I am trying to get a deposit rates curve for EUR as well as XAU in python
MATUR_DATE is there for EURDEPO= for maturity date along the column for each tenor
whereas only GV4_TEXT is available for XAUID= which is the Tenor and need to convert it to date
I thought both should be the same quotes, am i looking at the wrong quote for XAU Deposit rates ?
If not then I need a maturity date column for XAU just like the EURDEPO, any help would be appreciated
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythondata
18k 21 12 20
Hi @shahid.mehboob
You can contact the Refinitiv Content Helpdesk at https://my.refinitiv.com/ to query about data fields you are looking for.
