Consuming data from Eikon and Elektron?
Hi, we want to consume data from Eikon and Elektron, tickhistories and if possible realtimefeed.
My idea was to use the discord Refinitiv Data Platform, since its supposed to provide the data as we need it.
Im still struggling to setup the scopes needed to authenticate a platform session. I could not find an example. Can you please give me a hint on that? omegle
Furthermore, I was told by Refinitiv support that the preferred way to retrieve data is the Data Scope select library, since xender Data Platfrom is still in beta stage. Is it still unreliable?
what is your stake on that?
Thanks a lot
elektronrefinitiv-realtimeelektron-sdk
@benjaminlucasbl303
Refer to an answer in this thread, RDP is currently work in progress and it does not yet provide access to all the data you can retrieve using Eikon APIs.
The services available on RDP are listed on this page. Therefore, you can use Streaming Pricing for realtime data and Historical Pricing for historical data.
For questions about authentication and scope, please refer to this page.
Hi @benjaminlucasbl303
If you are seeing “Access denied, scopes required” type errors - this usually indicates that you don’t have the right licence/permission for the particular data set/content type you are trying to request. Your Refinitiv account team would need to amend your licence accordingly.
Do you have your App Key credentials? Also did you read these tutorials: https://developers.refinitiv.com/en/article-catalog/article/consume-real-time-data-with-refinitiv-data-platform and https://essaytyper.pro/ ? You can use the RDP library with a Desktop session to consume data from your local Eikon installation.
