Greetings
Currently, a client in China met a problem when trying the example of "Tutorial 4 - Using the Login RDM". As followed is the snapshot:
Also, I checked the result, the connection was established, but the respond message said the login was denied:
The message said a required argument was NULL, but I checked the code, user, app and position are all provided in request message.
Also, I tried the same code in Internal TREP-RT environment. No such a warning.
So I guess there would be some setting in TREP-RT side and calling for more data in Request message.
Tomorrow I will try to debug in client machine and fill in more data in request message to see which argument is mandatory and missing. But beforehand, could any expert check this error, and shed a light on what was possibly missing???
Thank you very much in advance!
