Can I send a message from visual basic ?
Hello, first at all, sorry about my English. My name is Ezequiel and I'm from Argentina and I'm trying to send messages to contacts that I have scheduled in an Access database.
There is a way to do it directly from Access or it would also be useful to do it from Visual Basic. Thank you.
messenger-bot-apivisual-basic
11.5k 16 7 10
Hello @ezequiel.mazzucchi
You can find the Messenger Bot API Postman example which gives you a demonstration of how to access the API via HTTP REST requests in Messenger Bot API Download page.
The page also contains a JavaScript/Node.js and Python example source code that shows how to use the BOT API REST and WebSocket connections which can be applied to any programming languages.
7.6k 15 6 9
@ezequiel.mazzucchi
If I understand your requirement correctly, you want to use Messenger Bot API to send a chat message to specific user on the Messenger. Is this correct?
Basically, the API just provides a set of HTTP requests to send and receive a message from the system. I believe that you should be able to use VB.NET /C# HTTP Client class to send the HTTP requests.
Please refer to a set of HTTP request messages you need to send/receive and its limitation from the following Messenger Bot document.
https://developers.refinitiv.com/messenger-api/messenger-bot-api/docs
