Hello @shehroz.khan,
If this error is not persistent, if it happens sometimes, it looks like a resource that RFA app needs, for example connectivity to EZD, DLL access, sufficient CPU or memory, becomes briefly unavailable to the app.
Once the availability of the resource is restored, RFA app will proceed as expected.
Does this happen at predictable times? If this is the case you may be able to figure out what causes the resource lock. I.e. market peak, or machine load peak due to other heavy jobs being run.
The other possible way to find out more is to enable tracing on RFA via trace parameters as described in RFA Configuration Guide or this thread and reviewing trace for when the issue occurs.
