Dear Team
how to get market price multiple item names in single call.
For example i am passing SGD= and JPY= and i need to receive price for both at a time.
Are you using windows 64bit?
As far as I understand on windows 64 bit you must change the registry path
from
HKEY_LOCAL_MACHINE\\SOFTWARE\\
to
HKEY_LOCAL_MACHINE\\SOFTWARE\\WOW6432Node\\
You need to search and replace the path on the source files and registry files. Also, you need to run it with Admin right if you turn on Windows Event Logger.
I would suggest you modify the codes to use RFA config from a file instead by changing WIN32 to WIN32x from the following line in StarterConsuemr.cpp
#ifdef WIN32x RFA_String exampleRfaCfgRegPath("HKEY_LOCAL_MACHINE\\SOFTWARE\\Reuters\\RFA\\Default", 0, false); AppUtil::log(__LINE__, AppUtil::TRACE, "Reading RFA configuration registry: %s", exampleRfaCfgRegPath.c_str()); result = _pStgCfgDataBase->load(windowsRegistry, exampleRfaCfgRegPath); ... #ifdef WIN32x RFA_String exampleAppCfgRegPath("HKEY_LOCAL_MACHINE\\SOFTWARE\\Reuters\\RFA\\StarterConsumer_BatchView", 0, false); AppUtil::log(__LINE__, AppUtil::TRACE, "Reading Aplication configuration registry: %s", exampleAppCfgRegPath.c_str()); result = _pAppStgCfgDataBase->load(windowsRegistry, exampleAppCfgRegPath);
Dear Team
I tried start consumer batch issue and i am getting login denied and connection got disconnected.
Attached is the cfg file and log file Kindly revert back
Hi @harik
Looking at your .cfg files the first thing I noted is that you have not set some key parameters
\service = "DIRECT_FEED" \session = "Session1" \userName = "user"
You need to specify a valid service name and dacs username.
Based on your various questions so far, I would recommend that you work through the tutorials so you can obtain a better understanding of how the API works - this should make your development progress much smoother.
You have to send a batch request instead. See example StarterConsumer_BatchView from the RFA C++ package. The following post explained how it works.
https://community.developers.refinitiv.com/questions/9385/rfa-batch-request.html
Further reading RFA C++ Developer Guide section from RFA C++ package.
section 7.8 Batch Messages and 15.1 Batch
I tried with multiple symbols (item names) i got error invalid registry path i ran the two reg file mentioned .What is the step i missed .
