RFA Timed out error
Hi Team
I got connection error when i tried with below information i got connection timeout error
Feeded Information
RDMExample -u TY6_03_RHB_SWVPNTRIAL01 -s hEDD -i IBM.N
Config file details
\Sessions\rdmExampleSession\connectionList = "Connection_RSSL"
\Connections\Connection_RSSL\connectionType = "RSSL"rfalog.txt
treprfarfa-api
rfalog.txt (2.9 KiB)
7.6k 15 6 9
@harik
Please open ExampleRFA.cfg and change elektron in the serverList to your ADS/Edge server.
\Connections\Connection_RSSL\serverList = "elektron"
Hi @harik
In one of your earlier posts, you specified an IP Address for the server - are you now trying to connect to a different server?
Or have you added a host entry for 'elektron' to your Windows hosts file with the IP address? If so try ping elektron from the cmd prompt - if it resolves to an IP address you know the host has been defined, but if it says could not find host then the host file was not successfully completed. Note that the Ping won't get a response either way.
