The move to using RDP instead of Eikon API??
I've been using the Eikon API, but recently discovered the RDP (Refinitiv Data Platform). The RDP looks to be where much of the future focus will be for Refinitiv. Currently, through the RDP, can I access everything that I currently can through the Eikon API? https://routerlogin.uno/ Since RDP is the future, I suspect that the RDP will (or may currently have) more features than Eikon API, so should I start to transition over to RDP now?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonrdp-api
9.5k 10 5 7
Hello @lakshadvio202
You may be able to start using some RDP endpoints because RDP is currently work in progress and it does not yet provide access to all the data you can retrieve using Eikon APIs. For more details, you may refer to the answer in this question.
Thanks for being sharing. Do also check here.
