Can't get earning release information via EIKON API.(via EIKON platform, ADVEV is correct.)
Hello, support team.
Can't get information earning release via EIKON API.
It seems that ADVEV(EIKON platform) information is correct.
Best regards,
7.6k 15 6 9
@kengo_takahashi
This seems to be a content issue for the RIC 3267.T
I test the RIC with Eikon Data API and found the same result and I can get the events from the previous month when I change stardate to Jan 2020. It looks like data is not updated.
It looks like both Eikon data API and Eikon Excel return NULL when testing with 3267.T. Below is a screenshot from Eikon Excel.
I would suggest you open a support case with the Eikon API support team via my.refinitiv.com to investigate the issue further.
