Option Chain using get_data
I am trying to pull the option chain corresponding to the RIC 0#BL2K0+. I can access the data as you can see from the screenshot below.
But when I run the get_data function to get the chain as per the suggestion in this query https://community.developers.refinitiv.com/questions/46401/ekget-data-on-option-chain-ticker.html
df, ek = e.get_data('0#BL2K0+', ['DSPLY_NAME'])
I get an error.
[{'code': 251658243,
'col': 1,
'message': "'Access Denied' for the instrument '0#BL2K0+'",
'row': 0}]
9.7k 49 38 60
Hi @varun.divakar,
The request you have is correct but it appears you are not permissioned to access this data.
The request will return data as:
I would suggest you reach out to your Refinitiv Account Manager to discuss your permission settings to access this content.
