Relocating LOG folders from Eikon.
If I'm not mistaken, Eikon produces some folders with .txt files inside them as logs when requests are made through its API.
Is there a way to change the location in which these are stored?
Thanks in advance!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonlogging
18k 21 12 20
Hi @aquilesjlp300
Please refer to this article on step 3.
I believe that you can set output folder for the log file.
Thanks for this, somehow it did not accept the locations I provided for the folders. I keep having log folders appearing with this format.
Also, when I check the default directory for the logs, the files that I get are different.
What could be the reason for this?
Any help is appreciated.
