Doubt about calculation of "TR.WACCBeta.value" in get_data()
I have a doubt about some values that I got when I run the code below:
ek.get_data('5411.T', fields=["TR.WACCBeta.date","TR.WACCBeta.value"], parameters={'SDate':'2020-03-01', 'EDate':'2020-03-31', 'Frq':'D'})[0]
I found seemingly unreasonable abrupt change in values on 2020-03-15 and 2020-03-16:
5411.T 2020-03-14T00:00:00Z 1.732474
5411.T 2020-03-15T00:00:00Z 1.253408
5411.T 2020-03-16T00:00:00Z 1.161265
5411.T 2020-03-17T00:00:00Z 1.711114
5411.T 2020-03-18T00:00:00Z 1.742852
5411.T 2020-03-19T00:00:00Z 1.798471
I understand that this beta is calculated with the order of preference: 5Y monthly, 3Y weekly, 2Y weekly, 180D daily, 90D daily, and I suspect that it has something to do with these settings of duration and frequency. The thing is that 5411.T has long track record and I'm sure that 5Y monthly data has been always available at least recently. Could somebody look into this sudden level shift followed by come-back on the original track? Thank you!
18k 21 12 20
Hi @iwasakI
First of all, I can confirm that the coding you provided is valid and it retrieves the same data on Eikon Excel.
This forum is not the best place to ask about content questions. For an authoritative answer to any content questions, the best resource is the Refinitiv Content Helpdesk.
This forum is dedicated to things specific to the use of Eikon APIs.
The moderators here do not have deep expertise in every type of content available through Eikon.
The Refinitiv Content Helpdesk can be reached using Contact Us capability in your Eikon application or by calling the Helpdesk number in your country.
