How will I be able to solve this?
gaierror                                  Traceback (most recent call last)
~\anaconda3\lib\site-packages\urllib3\connection.py in _new_conn(self)
    156             conn = connection.create_connection(
--> 157                 (self._dns_host, self.port), self.timeout, **extra_kw
    158             )
~\anaconda3\lib\site-packages\urllib3\util\connection.py in create_connection(address, timeout, source_address, socket_options)
     60 ---> 61     for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
     62         af, socktype, proto, canonname, sa = res
~\anaconda3\lib\socket.py in getaddrinfo(host, port, family, type, proto, flags)
    751     addrlist = []
--> 752     for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
    753         af, socktype, proto, canonname, sa = res
gaierror: [Errno 11001] getaddrinfo failed
During handling of the above exception, another exception occurred:
NewConnectionError                        Traceback (most recent call last)
~\anaconda3\lib\site-packages\urllib3\connectionpool.py in urlopen(self, method, url, body, headers, retries, redirect, assert_same_host, timeout, pool_timeout, release_conn, chunked, body_pos, **response_kw)
    671                 headers=headers,
--> 672                 chunked=chunked,
    673             )
~\anaconda3\lib\site-packages\urllib3\connectionpool.py in _make_request(self, conn, method, url, timeout, chunked, **httplib_request_kw)
    375         try:
--> 376             self._validate_conn(conn)
    377         except (SocketTimeout, BaseSSLError) as e:
~\anaconda3\lib\site-packages\urllib3\connectionpool.py in _validate_conn(self, conn)
    993         if not getattr(conn, "sock", None):  # AppEngine might not have  `.sock`
--> 994             conn.connect()
    995
~\anaconda3\lib\site-packages\urllib3\connection.py in connect(self)
    299         # Add certificate verification
--> 300         conn = self._new_conn()
    301         hostname = self.host
    168             raise NewConnectionError(
--> 169                 self, "Failed to establish a new connection: %s" % e
    170             )
NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x0000016CCF111CC8>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed
MaxRetryError                             Traceback (most recent call last)
~\anaconda3\lib\site-packages\requests\adapters.py in send(self, request, stream, timeout, verify, cert, proxies)
    448                     retries=self.max_retries,
--> 449                     timeout=timeout
    450                 )
    719             retries = retries.increment(
--> 720                 method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
    721             )
~\anaconda3\lib\site-packages\urllib3\util\retry.py in increment(self, method, url, response, error, _pool, _stacktrace)
    435         if new_retry.is_exhausted():
--> 436             raise MaxRetryError(_pool, url, error or ResponseError(cause))
    437
MaxRetryError: HTTPSConnectionPool(host='graph.www.facebook.com', port=443): Max retries exceeded with url: /me?fields=id,%20name,%20friends.limit(10).fields(likes.limit(10))&access_token=EAAIcZAdOgAEwBAATLvKbGPAr92D7SK8ZAZADMghRIdNDZAv3oyYmf8vRkbxWCdkwgC7GQ7YdVsBxw6dX1u6BZAkhJm5Eqc8hyN6pvozvaFTgAEidl4ZCQZDZD (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x0000016CCF111CC8>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
<ipython-input-5-85557f6e22f3> in <module>
----> 1 content = requests.get(url, timeout=5).json()
      2 print (json.dumps(content, indent=1))
~\anaconda3\lib\site-packages\requests\api.py in get(url, params, **kwargs)
     74      75     kwargs.setdefault('allow_redirects', True)
---> 76     return request('get', url, params=params, **kwargs)
     77      78
~\anaconda3\lib\site-packages\requests\api.py in request(method, url, **kwargs)
     59     # cases, and look like a memory leak in others.
     60     with sessions.Session() as session:
---> 61         return session.request(method=method, url=url, **kwargs)
     62      63
~\anaconda3\lib\site-packages\requests\sessions.py in request(self, method, url, params, data, headers, cookies, files, auth, timeout, allow_redirects, proxies, hooks, stream, verify, cert, json)
    528         }
    529         send_kwargs.update(settings)
--> 530         resp = self.send(prep, **send_kwargs)
    531     532         return resp
~\anaconda3\lib\site-packages\requests\sessions.py in send(self, request, **kwargs)
    641     642         # Send the request
--> 643         r = adapter.send(request, **kwargs)
    644     645         # Total elapsed time of the request (approximately)
    514                 raise SSLError(e, request=request)
    515 --> 516             raise ConnectionError(e, request=request)
    517     518         except ClosedPoolError as e:
ConnectionError: HTTPSConnectionPool(host='graph.www.facebook.com', port=443): Max retries exceeded with url: /me?fields=id,%20name,%20friends.limit(10).fields(likes.limit(10))&access_token=EAAIcZAdO4HTrqD7SK8ZAZADMghRIdNDZAv3oyYmf8vRkbxWCdkwgC7GQ7YdVsBxw6dX1u6BZAkhJm5Eqc8hyN6pvozvaFTgAEidl4ZCQZDZD (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x0000016CCF111CC8>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
pythonapi
Sorry, this forum is only for Refinitiv technologies and API. Please post your question in Python support.
