Downloading compressed file on TRTH
I run into out of memory exception when I add new lines to response body by "using (var gzip = new GZipInputStream(streamResponse.Stream))" after "var streamResponse = ExtractionsContext.GetReadStream(extractionResult);".
I tried to get L1 data for one day for two chain ric "0#HSI:", "0#HCEI:" and got the above issue
is it possible that I just download the compressed file only? How can I do that? I will decompress the file in later stages.
Or is there a better option regarding my above issue?
It does work if I submit a request with a smaller number of identifiers. But this is not the ideal solution.
Though I will not run into “out of memory” exception, the needed time is still way too long.
dss-rest-apidatascope-selectdsstick-history-rest-api
@Mohamed.Hisham
Please refer to the .Net SDK Tutorial 5: On Demand extraction, file IO tutorial.
It demonstrates how to set AutomaticDecompression to false and save the data in compressed format.
//Direct download from AWS ?
if (awsDownload) { extractionsContext.DefaultRequestHeaders.Add("x-direct-download", "true"); };
DssStreamResponse streamResponse = extractionsContext.GetReadStream(extractionResult);
using (FileStream fileStream = File.Create(dataOutputFile))
    streamResponse.Stream.CopyTo(fileStream);
//Reset header after direct download from AWS ?
if (awsDownload) { extractionsContext.DefaultRequestHeaders.Remove("x-direct-download"); };
Console.WriteLine("Saved the compressed data file to disk:\n" + gzipDataOutputFile);
