How to Plot Streaming Data from ek.StreamingPrices?
I've successfully used created a cache using ek.StreamingPrices and have been able to see a pandas DataFrame update with streaming prices. However this is all i am able to do. I am wondering how you can further utilize this data and work with it. I am looking primarily to visualize streaming prices but have no luck. Any help would be appreciated, Thanks!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonrefinitiv-realtimestreaming-prices
Hi @r.patel. Are you using the `on.update = ` parameter to write to the DataFrame? Do you mind appending some code example to your question for that part?
Code that is almost identical to what I was using is in Nick Zinconne's response below
18k 21 12 20
Hi @r.patel
According to your post, I understand that you already have data in a dataframe.
So you can read this article to visualize the data to many chart types.
https://pandas.pydata.org/pandas-docs/stable/user_guide/visualization.html
9.7k 49 38 60
Hi @r.patel,
In terms of what the API can do for you, it will maintain an up-to-date cache of the data - which is what you are currently using it for. It also provides the ability to capture realtime updates through lambda expressions. For example, from the Eikon PiPy page:
With this capability in place, you can visualize streaming data within your applications based on changes in the market.
