TREP API connectivity failover issues
Hi Developer Support,
We are observing some failover issues with our processes connecting to the TREP edge servers via the Refinitiv APIs.
In this instance, we notice the API repeatedly tries to login to another channel but kept failing.
Channel 1 and 3 are configured to the same TREP server IP and port but the connection has been refused.
Please see the log snippets below:
2020-03-18 10:47:18.869 INFO [pool-2-thread-1] OmmConsumerImpl - loggerMsg
Severity: Info
Text: Received ChannelUp event on channel Channel_3
Instance Name Consumer_1_1
Component Version ads3.3.1.L1.linux.tis.rrg 64-bit
loggerMsgEnd
2020-03-18 10:47:33.904 WARN [pool-2-thread-1] OmmConsumerImpl - loggerMsg
ClientName: LoginCallbackClient
Severity: Warning
Text: RDMLogin stream state was changed to suspect with status message
username <not set>
usernameType <not set>
State: Open/Suspect/None - text: ""
loggerMsgEnd
2020-03-18 10:47:33.904 INFO [pool-2-thread-1] RTROmmConsumer - [registerClient] Item: <not set> / Service: <not set> [State: Open / Suspect / None / '']
2020-03-18 10:47:36.744 INFO [Thread-7] SL_SubMgr - proUnsub starting check
2020-03-18 10:47:36.744 INFO [Thread-7] SL_SubMgr - proUnsub check end. Count=1
2020-03-18 10:47:48.933 WARN [pool-2-thread-1] OmmConsumerImpl - loggerMsg
Severity: Warning
username <not set>
We decided to kill + restart our processes and managed to re-established connectivity without any issues back at channel 1.
As such, we are inclined to believe that there isn’t any issues on the TREP edge server end.
We are concerned if such errors messages are due to any missing parameters within the EmaConfig.xml file perhaps?
Thank you.
Regards,
Alan
elektronrefinitiv-realtimeelektron-sdktreprrtema-apielektron-message-api
23k 22 9 14
Hello @AlanAng,
Looks like you are connecting to ELEKTRON via local, deployed TREP?
Elektron SDK, EMA, what version?
Running a custom EMA consumer?
I think that if the consumer was working normally prior to the disconnect, have experienced the disconnect and, once restarted, was able to reconnect, all using the same EmaConfig.xml, then EmaConfig.xml should be valid. However, please attach (ok to substitute any info with XXX) will try to verify.
Was your configuration or application modified recently?
If you are connecting via deployed TREP, managed by your organizations' market data group, perhaps it would make sense to verify with them, that there were no intermittent outages at the time of this occurrence?
